查看: 8336|回复: 3
[Firmware update] HW v2.82 and DFU v3.46C details!
91
发表于 2016-5-25 19:59:35 | 显示全部楼层 |阅读模式
[i = s] posts by TnF in 2016-5-25 20:14 Edit
Hello. Can you provide description details for the new hardware v2.82? Everyone is wondering what are the changes :p
Also can you provide DFU v3.46C hex file? I know how to update via the ST programmer like i did last time (i went from v3.40C>>v3.45C).
I have HW v2.81 at the moment running DFU v3.45C and SYS v1.64. Will DFU v3.46C be compatible with v2.81?
Kind regards
2117
发表于 2016-5-26 09:21:10 | 显示全部楼层
HW2.82 is only a small part of the layout is different, the same hardware and DFU3.46, HW2.81 compatible with HW2.81
DS203_P-D346CS164A113P10F26A(27AB).rar (133.87 KB, 下载次数: 2279)
91
 楼主| 发表于 2016-5-31 22:49:54 | 显示全部楼层
Ok thanks for the reply, i will flash it in a bit. What are the changes in the latest DFU v3.46? Better windows 10 support?
277
发表于 2016-6-1 09:41:20 | 显示全部楼层
TnF 发表于 2016-5-31 22:49
Ok thanks for the reply, i will flash it in a bit. What are the changes in the latest DFU v3.46? Bet ...
After DFU3.42 support Win10, DFU3.46 is perfect for MAC OS
GMT+8, 2020-10-30 13:10 , Processed in 0.103126 second(s), 24 queries .
