楼主: minidso
[Firmware update] Material Download for ES120/121/121V/Plus Motion Control Electric Screwdriver
2041
 楼主| 发表于 2018-9-25 18:03:19 | 显示全部楼层
P mode is torque changing with rotation angle.
The A mode is the change of rotation speed with rotation angle.
发表于 2018-9-25 19:36:33 | 显示全部楼层
Thanks! That is very clear and helpful!
4
发表于 2018-10-11 06:27:57 | 显示全部楼层
When I copy over the Hex file, the screwdriver reboots, and there is a file "ES120-~1.ERR". The firmware does not update.
I have tried 1.7a, 1.8, and 1.10. All do the same thing.
2041
 楼主| 发表于 2018-10-11 09:52:52 | 显示全部楼层
toddkrein 发表于 2018-10-11 06:27
When I copy over the Hex file, the screwdriver reboots, and there is a file "ES120-~1.ERR". The firm ...
What OS you use? Please try WIN7 and try another usb line.
4
发表于 2018-10-11 14:43:22 | 显示全部楼层
OK, I think I found it. I tried it under Linux, and got the same error. When I renamed the file to V110.hex before I copied it over, it worked fine. (Finally)
I'm guessing that it's a filename length issue.
107
WS Cell
发表于 2018-10-11 18:56:48 | 显示全部楼层
martinbogo 发表于 2017-8-7 13:49
Please update on the status of release of the firmware for ES-120.   I would like to contri ...
Hello, MARTIN !!! have you created the custom firmware with the precise torque adjustment ??? I would like to test in my ES121, could you send it to my email ???
william.021@icloud.com
thank you!!!!!!!!!!!!!!
William S. Silva
2041
 楼主| 发表于 2018-10-12 10:04:58 | 显示全部楼层
William021 发表于 2018-10-11 18:56
Hello, MARTIN !!! have you created the custom firmware with the precise torque adjustment ??? I wo ...
The ES120 and ES121 now adjust the torque by controlling the current output.
The firmware is open source and you can modify it yourself.
发表于 2018-11-19 03:17:38 | 显示全部楼层
下载说明书先学习起来
发表于 2018-11-22 22:51:01 | 显示全部楼层
where can I find the source code of the latest 1.10 firmware? There's only the hex file in the archive, and source code archives in the post is the latest 1.8, but no 1.9 or 1.10 source.
thanks!
jojojo
2041
 楼主| 发表于 2018-11-23 09:12:21 | 显示全部楼层
jojojo 发表于 2018-11-22 22:51
where can I find the source code of the latest 1.10 firmware? There's only the hex file in t ...
Wait, I upload.
GMT+8, 2020-6-6 06:28 , Processed in 0.116266 second(s), 19 queries .
