查看: 2245|回复: 3
[Troubleshooting] TS100 replacement tip problem
4
发表于 2017-6-24 01:11:46 | 显示全部楼层 |阅读模式
[i = s] posts by boosen in 2017-6-25 23:00 Edit
[i = s] posts by boosen in 2017-6-24 03:41 Edit
[i = s] posts by boosen in 2017-6-24 03:12 Edit
Hey friends!
I just received my TS100 from banggood and a replacement tip. The tip that came with the TS100 works fine, but the replacement tip acts weird, have a look for yourself:
https://www.youtube.com/watch?v=VbVBNiePtmQ
I already updated the firmware, tried to eject and insert the tip several times without any luck.
To clarify the problem: The temperature readings of the replacement tip overshoot and the soldering iron fails to keep the temperature steady. When cooling down the temperature reading seem to work just fine. This is a brand new tip, I bought this one: https://eu.banggood.com/Wholesale-Warehouse-Original-Replacement-Solder-Tip-For-TS100-Digital-LCD-Soldering-Iron-wp-Eu-984215.htm Model no. TS-BC2
Greetings!
boosen
EDIT: I solved the issue!
I just read the manual and discovered this:
Problem 2:
Every time when installing
a new tip, the temperature status display
random numbers
Means the machine is checking status, which is normal
So I just waited about half a minute, switched the iron off and on again.. and hooray, it works now!
Great soldering iron!
相关帖子
4
 楼主| 发表于 2017-6-24 20:25:38 | 显示全部楼层
Nobody?
4
 楼主| 发表于 2017-6-25 22:58:44 | 显示全部楼层
I solved it
Problem 2:
random numbers
1917
发表于 2017-6-26 10:12:27 | 显示全部楼层
When each new iron head is heated for the first time, the temperature changes randomly, and it stabilizes in about 30 seconds. The next time you use the iron head, that won't happen.
GMT+8, 2019-11-19 01:02 , Processed in 0.131054 second(s), 25 queries .
© 2001-2017 Comsenz Inc.
