查看: 3012|回复: 4
[Troubleshooting] No Space for Configuration
发表于 2017-7-13 02:59:05 | 显示全部楼层 |阅读模式
Hello together, when i plug my ts100 via USB there is only 8KB space on it. When i try to change the configuration, my mac told me the space is full. i can't load a boot screen img too. i only change some numbers in the txt file and press safe. then my mac tells me there is no space for saving. can you help me plz. sry for my bad english. THX
45
发表于 2017-7-13 11:04:48 | 显示全部楼层
What version of firmware(hex) are you using now.
4
发表于 2017-7-18 19:11:49 | 显示全部楼层
ny! Posted 2017-7-13 11:04
I have exactly the same issue, under windows and linux.
the display shows 2.12 on startup
the removable drive only shows a CONFIG.TXT file, and windows (and linux) say there are 7168 bytes free of 8192 bytes total.
help? please?
发表于 2017-11-28 11:09:03 | 显示全部楼层
I am having the same problem, is there a fix for this yet?
45
发表于 2017-11-29 10:18:14 | 显示全部楼层
The size is 8kb and you can add 96*16 images if you want to modify your own ICONS.Importantly, the file name must be LOGOIN. BMP.
GMT+8, 2019-11-19 07:51 , Processed in 0.096509 second(s), 20 queries .
© 2001-2017 Comsenz Inc.
