查看: 2934|回复: 0
[意见建议] RPM set menu
29
发表于 2017-8-20 02:59:10 | 显示全部楼层 |阅读模式
[i = s] posts by GeorgeB in 2017-8-20 03:01 Edit
Include a menu to set max. RPM ahead of time, so the speed is consistent every time.
Minimum function would be to select between 200/400 RPM, but better would be to select speed +/- 50 RPM each step.So, 50 RPM minimum, then 100, 150, 200, 250, 300, 350, and then 400 RPM.
GMT+8, 2020-4-5 10:52 , Processed in 0.069904 second(s), 20 queries .
