查看: 1277|回复: 1
Error saving DS 212 file
发表于 2018-11-9 10:50:50 | 显示全部楼层 |阅读模式
If you turn the power off, the scope operation will be done by default but file saving and state saving will also be disabled.
7 H6 n& \- E( x# s
" p5 Z1 @0 C5 U$ _, dIf you connect the USB cable while the DS212 power is turned on, you will be prompted to format the disk.
% i+ x7 h% G" G* Z$ q) m0 e( b4 X/ R
What should I do?
2082
发表于 2018-11-15 09:17:54 | 显示全部楼层
Try format the disk with "FAT"
GMT+8, 2020-8-10 16:51 , Processed in 0.123039 second(s), 21 queries .
