查看: 1416|回复: 2
[疑难问题] Issue: No output without direct modules connection
20
发表于 2019-9-3 18:08:59 | 显示全部楼层 |阅读模式
If both modules(M01 and P905) are not direct connected with cable, output voltage oscillate around  zero as in pictures. Power plugs are lighted.
Only if they were connected before power up I cold get desired output.
Both FW versions v1.2
Standalone P905 also do not keep output voltage
2066
发表于 2019-9-4 10:21:42 | 显示全部楼层
This bug has been corrected in the new firmware.
Have you upgraded to the latest firmware? The firmware in this link has changed.
http://minidso.com/forum.php?mod=viewthread&tid=3685
20
 楼主| 发表于 2019-9-6 21:40:06 | 显示全部楼层
Modules already came with v1.20
GMT+8, 2020-7-14 14:41 , Processed in 0.251626 second(s), 24 queries .
