查看: 42746|回复: 6
[Firmware update] DS203_2.81 version Descriptions
1944
发表于 2014-10-21 15:19:37 | 显示全部楼层 |阅读模式
Hardware Ver 2.81 version of the DS203 uses new model of FPGA. Therefore FPGA and LOGO updated boot file FPGA_281.ADR, 281_FPGA.BIN and LOGO_281.ADR with Ver 2.72 and previous versions, so be sure to update the corresponding version. SYS and APP programs are generic functions are the same.
In the hardware function and the performance indexes, Ver 2.81 and Ver 2.72 are the same.
LOGO_281.ADR (12 Bytes, 下载次数: 6110)
1944
 楼主| 发表于 2015-12-24 16:46:46 | 显示全部楼层
pabickwermert 发表于 2015-12-24 15:28
Hi. Can I update my ds203 v2.7 to 2.81?
Thanks.
No, You can not upgrade
回复 支持 1 反对 0
34
发表于 2015-12-24 05:52:36 | 显示全部楼层
Somehow with my DSO HW2.81, the welcome screen LOGO image was corrupted and not displayed.  Above download files include the LOGO 281.ADR file, but not the LOGO.bin file.
I was able to restore my DSO's welcome screen LOGO image, using the LOGO.bin file from an earlier firmware update, then use it with the LOGO 281.ADR file provided.
If you want to modify the LOGO image displayed, you can rename the LOGO.bin file extension to PNG, then load this PNG file in MS Paint for editing.  The Paint program will show the pixel resolution (256x64) that the DSO accepts.  After you edit/modify/save the LOGO.PNG file in Paint, rename it back to LOGO.bin for loading to the DSO in DFU mode.  Easy!
Hope this helps.
4
发表于 2015-12-24 15:28:33 | 显示全部楼层
Thanks.
16
发表于 2017-3-4 05:59:39 | 显示全部楼层
Good afternoon I would like to know if there is any new firmware update of the ds203 (SYS and APP)
1944
 楼主| 发表于 2017-3-6 09:18:12 | 显示全部楼层
APP V 1.13 is the new one
发表于 2018-10-31 23:59:06 | 显示全部楼层
[i = s] posts by Peter in 2018-11-1 00:06 Edit
[i = s] posts by Peter in 2018-11-1 00:05 Edit
1 - Non fa la funzione (A-B). Con (A+B) penso che vada bene perchè da la somma dei valori dei due canali.
2 - I parametri del canale CH(D), anche se impostati di colore VERDE, vengono riportati di colore VIOLA come il canale CH(C).
Gradirei avere spiegazioni.
Cordiali saluti
GMT+8, 2020-1-28 12:23 , Processed in 0.230441 second(s), 25 queries .
