返回列表 发新帖
楼主: TnF
[Sharing /User Voice] Tutorial: How to flash/debrick/update DFU on DSO203 HW V2.81
10
发表于 2018-4-6 00:04:54 | 显示全部楼层
Is this different for Hardware Version 2.82? Can we use the above firmware, since it said its only for v2.81.
16
发表于 2018-11-27 07:01:24 | 显示全部楼层
sagittarius Posted 2015-9-18 10:17
I'm sorry, due to the file didn't explain before, let you made a mistake. "Default.hex" The hex fil ...
This file is no longer available - can you provide a valid link, please ?
4
发表于 2019-11-13 00:15:10 | 显示全部楼层
hi.
https://www100.zippyshare.com/v/ehpbuC41/file.html
11
发表于 2019-12-29 18:57:11 | 显示全部楼层
Please send a new link to the Boot file. All links in this thread do not work.
282
Rank: 3Rank: 3
发表于 2020-1-7 11:24:26 | 显示全部楼层
found the rar file from first post
https://mega.nz/#!QXAA1YjC!nonHD ... S8vvoCh1DNSEtFk82YM
And DS203_Boot(HW272).hex
https://mega.nz/#!BbJUQaCK!Edqg5 ... 3jhljSJdVYUWZCsnloU
Maybe this help DS203.V2.72.zip
https://mega.nz/#!9PQkXSwb!AWGpi ... lyZv-IAqwwCr9_EDp48
发表于 2020-6-10 03:44:27 | 显示全部楼层
I have an older version of the fantastic DS203 which I am running with an alternative firmware.
Since the USB firmware upload is not working I would like to upgrade the firmware to a version that is compatible with Windows 10.
My board version is DS203V2.7B
DFU V3.10
HW Version 2.60
System version 1.52
Serial number: 156d5fdb
Can I use the firmware verion of 2.72?
I would be glad if someone could send  me the license code.
Thank you!
282
Rank: 3Rank: 3
发表于 2020-6-11 08:31:03 | 显示全部楼层
When you enter DPU mode you will License.
It should be lic: 4425921A or lic: 90632516
The firmware APP and SYS it compatible with all HW. The DPU and FPGA must used 2.72 for older HW.
GMT+8, 2020-9-20 03:43 , Processed in 0.064175 second(s), 18 queries .
